CRX w/ B16 shift linkage slop while in gear (under car):
CRX w/ B16 shift linkage slop:
my shift linkage used to be horribly lose when in gear, it was almost the exact same when in neutral or in gear. so I bought a new u joint to weld to the front of the linkage but before I did that I found some "Jesus clips" or U shaped clips and wedged them in the front of the linkage hinge between the bushings and the metal of linkage. this has definitely tightened up the linkage a lot but I still have some movement in it. Here is a video for you to see how much it moves when in gear and also the movement from under the car. By the way I already have installed the Energy Suspension bushing kit which didn't seem to help much. I believe the shift linkage is a hasport because the motor mounts for the b16 swap are hasport. should it have some kind of label on it?
