This is a 2-part question...for anyone who has done their OWN head work. I'm in the process of hand-lapping the valves on my HF (thank GOD it's only 8 valves). What a PITA! I'm trying to be as meticulous as possible with the cleaning of the valve and the oil on the valve stem while I'm lapping it..and the valve grinding compound on the valve seat, etc. But each time I think I'm done, I re-clean the valve and re-install it in the head ONLY to have the leaks show up again when I perform the little leak-test-trick (filling the intake/exhaust ports with fluid and then waiting to see if it starts weeping at the combustion side of the valve).
Part 2: Even if I can get just ONE valve to hold water during this test, NONE of them seem to be able to hold back gasoline (if I use gasoline instead of water for this test). Yes, I realize water is going to be larger molecules, which is why its holding. Just want to know about the gas/alcohol. Can anyone confirm whether or not water is a good enough test, or should the cylinder head also be capable of holding back gasoline (or even alcohol)? I just want to make sure it's right before I put it back on the car...and if I give up I guess I'll just have to call myself incapable - and just drop it off at a machine shop. Jeez! I was hoping to be able to do SOMETHING with this rebuild on my own.
Thanks for any/all help.
