I posted that, but seems one of my edits didn't go thru.
With a chipped ecu you have to carry a laptop with you to make the changes, something you cannot do once you're near the burnout box.
With the setup I'll be running I'll be able to adjust right before staging if needed. While this might be extreme for most, I'll be running points series next year at local 1/4 track, bracket racing for points AND money.
Yes, it is needed to be deadly consistent.
old .500 tree
AMSOIL STREET CLASS RULES
* E.T. break 12.00 - 19.99 *
* Slicks permitted *
* Open headers permitted *
* Helmet required for 13.99 and quicker(Snell 2000 or newer) *
* Master cutoff switch required if the battery has been relocated to the trunk area *
* Seat belt mandatory *
* No shorts or sleeveless shirts *
* Cooling system overflow/catch can required *
* Driveshaft loop required if running 13.99 or quicker AND utilizing slicks (not required if running street tires) *
* One line loc only permitted, and only on non-drive wheels *
