Honda Ballade 150i SOHC automatic
4.6K views 6 replies 3 participants last post by  Baker
#1 ·
Hello all
I am in the process of doing a water pump and timing belt renewal on the abovementioned vehicle.
What I would like to know is if the timing mark on the crank pulley would be the same?
I used the CRX SOHC manual and it shows this:
Would this be okay to do on this car?
Thank you :)
#7 ·
Little Red said:
It is a '92 model as well.
So, same year as the CRX SOHC, too.
I'm not sure of the engine code, but it is one like this:
Things don't match up...
You show a 96-00 body style, but say it's a '92, you show a SOHC engine, but then say your engine is a d16a9, which is a DOHC.
Find out what your engine is really, then look it up from there.
Your engine code & motor's serial number is engraved on the exhaust side of the motor, to the left of the exhaust manifold, up near where the block meets the head.
