BannisteR's '90 EF8 SiR Glasstop Build.
205K views 741 replies 122 participants last post by  Nar
#1 ·
Hello CRXcommunity.com, I'm BannisteR and here is my project car.
I picked her up December of 07 as a stripped shell. The shell was in great shape, no body rot or rust and had paperwork. Hasn't been registered stateside yet. She had doors, dash, carpet, hatch and haggard suspension. Picked up a set of HX wheels to roll her onto the tailor to get home and roll around in the garage. I'm currently stationed in VA and the car is in Cali safe in the garage. I will be getting hot and heavy into the build up of her very shortly as ill be bringing her out to VA so I will have ample time to work on it.
Most current state as of September '10:
Just a few of the parts that I've been collecting...
Few other pics...
Here's a rundown of the parts I've put on/ collected so far
-INTERIOR-
*EF8 door cards
*EF8 power windows
*EF8 rear interior including rear seat and bass tubes
*EF8 access floor mats
*Custom "personal box" w/ yellow flocking
*Custom "coin tray" w/ yellow flocking
*AP1 cluster with Qube engineering LED conversion (white)
*DC2 ITR black w/ yellow stitch shift boot
*NRG short hub
*Works Bell quick release
*Personal Black w/ yellow stitching wheel / Vertex 10 star in blue
*Spoon Sports Ti knob / Vertex white delrin / J's burnt Ti
*Spoon Sports DC2 rear view mirror insert
*DC2 rear view mirror
*Mugen DC2 mirror cover in NH-0
*Bride EF8 seat rails
*Spoon Reclneable seat
-SUSPENSION/BRAKES-
*EF8 miracle X crossbar
*EF/ITR Function7 lower control arms
*Fortune Auto 500 coilovers w/ Swift spring upgrade.
*HardRace upper control arms
*HardRace rear camber kit
*HardRace EF bushing kit
*Full Race front cross member/ traction bar
*ASR EF rear sway bar and subframe brace
*Spoon Sports EF8 rigid collar kit
*Spoon Sports EF front strut bar / Circuit Sports strut bar
*Spoon Sports EG/DC rear lower tie bar
*Spoon Sports EG6 torque damper
*Wilwood 4 piston w/ 11" rotors (front)
*Wilwood large single piston parking brake calipers w/ 11" rotors (rear)
*Goodridge stainless steel braided brake lines
*H&R extended studs
*Powder coated gunmetal suspension components
-MOTOR/PERF-
*'98 USDM B18C5 w/ OEM ITR 81.25 pistons
*ITR head
*USDM ITR Trans
*ACL race bearings
*Buddy Club Spec II exhaust
*Password JDM battery relocate kit
*Spoon Sports DC2 Radiator hoses
*Spoon Sports 4-2-1 header
*Spoon Sports radiator cap
*Spoon Sports oil cap
*Spoon Sports carbon kevlar spark plug cover
*Spoon Sports thermostat switch
*Spoon Sports gen2 cam gears
*Spoon Sports high tension cords
*Spoon Sports heat barrier tape
*Spoon Sports radiator stays
*Spoon Sports drain and oil plug
*Spoon Sports head gasket
*M's Factory Sport injection kit (ITB's)
*Skunk2 tuner stage 2 cams
*Skunk2 valve springs
*Skunk2 Ti retainers
*Skunk2 composite fuel rail
*Skunk2 VTEC solenoid
*Skunk2 VTEC solenoid cap
*Skunk2 cam seal
*Skunk2 valve cover flush mount bolts
*Hondata intake manifold gasket
*Hasport EFB2 mounts
*Hasport shift linkage
*Hasport axles
*C&R radiator
-EXTERIOR-
*EE8 EDM taillights w/ rear fog light
*EF8 Honda Access visors
*EF8 bumper lights
*EF8 corner lights
*EF8 side markers
*EF8 J's Racing hood / EF8 OEM style fiberglass hood
*EF8 front bumper
*EE8 EDM glass headlights
*EF8 OEM service tags for doors, and under hood
*EF8 JDM headlights retrofitted w/ E55 bi-xenon projectors and shrouds
*The Retrofit Source Bi-xenon plug and play harness
*OEM EF8 fenders
*Password JDM EF8 carbon fiber lip
*JDMSh!t EF8 polyurethane lip
*Vision EF8 carbon fiber mirrors
*OEM Honda 91 door moldings, gaskets, seals (lots or brand new OEM goodies)
*Spoon Sports wiper brades
*Spoon Sports windshield banner
*Spoon Sports rear window banner
*Spoon Sports license plate in yellow and blue
-WHEELS-
*Sprint Heart Formula CPR's 16x7 +38
*Volk Rays SE37K's 16x7+33
*Work Meister's 16x7+27
Lots more to get...
Here was the daily... '98 ITR #0179
#728 ·
With any build there will be setbacks, mine is no exception...
My old CRX is an EF7 model. With that many of the US parts made for the US chassis cars were utilized on that car. I had Hasport EFB2 mounts to utilize a hydraulic transmissionas well as a full race traction bar. I quickly found out I would not be able to use those items. I contacted Hasport directly to see what they had for mounts. They have one option... one... OEM replacement mounts. So no option to utilize a hydro trans either :| My option is to go with a cable trans or I could find a big spline YS1 trans to use the case to run the ITR internals and LSD. I had to order a new traction bar as well, I went with the K-tuned traction bar.
That's about it for updates as of now. Cars at the shop being stripped and prepped for paint.
audmcrx said:
What do you plan to do with the mugen kit?
Seems a shame to not use it but taste is taste I guess
Sold it already. They are a good looking kit but not the route I'm going with the car.
#730 ·
I have a few pics from the past couple weeks of getting work done on the shell. Glass has been removed, doors and hatch as well. Nothing huge yet nor any final color sprayed but progress is progress. The bumper lights, taillights, and headlight lenses have been cleared so they will have long lasting protection as well as be clean and glossy for years to come. The doors, hatch, hinges and other misc. parts were media blasted then epoxied.
Another project ongoing at the shop as well, 911 getting turbo flares and and all over refresh.
The shell got a little bit of attention with being stripped and got some epoxy.
91torinoredcrx said:
Very good decision on NOT using the atrocious MĂĽgen body kit!
It's not for me that's for sure haha.
#731 ·
No pics of progress but I'll hopefully have some next week as I plan to visit the shop to assist where I can and check progress. Lots of work stripping everything down and fixing any and all body work. The bay is currently getting a few portions filled and smoothed out, not doing a fully shaved bay just taking out brackets and holes that aren't used. I've sourced a set of clear bumper lenses and cut up a spare set of bumper lights to make a clear set. I also made a set of DC2 clear sidemarkers with LED internals. I just got my headlight lenses back for my headlights so I can finally finish my HID retrofit! Lots more to go but progress is being made.
#732 ·
The past couple months have been hectic, car is still at paint and rounding near completion (as far as paint goes) I've been dropping by the body shop and helping when I can with prep, assembly and some block work. It's nice to have the opportunity to be personally involved with this process. I didn't have the interior or the car painted because I had plans of painting that myself. While the car was in epoxy and primer a buddy of mine and I went over to the shop and marine coated the interior in a deck gray. I wasn't worried on it not matching the exterior, I just didn't want any more red on the car. I'll have full interior so 85% of this won't be seen anyways, the rear behind the seat and spare tire well will be about the only part of this that would be seen.
The shell is completely painted now, all the glass is back in and none of the bronze glass was sacrificed in that process :D I'm waiting on the bumpers and hoods to be finished up and start reassembly! What a feeling it is opening all these new Honda refresh seals and gaskets I've been collecting all these years to put on a fresh and new looking car. I also had a sinking feeling when the upper door moldings didn't fit... When I ordered these parts 7+ years ago I didn't realize that Japanese doors were only comparable with 88 CRX parts (pillar mounted seat belts) so I had so search for the two discontinued moldings. One was sourced from a dealership in WA state and the other after about a week of panic and people giving me ridiculous prices (also not willing to sell just the one side) I found one, in Osaka Japan. I ordered it and three weeks later "overnight parts from Japan"
Here's a few pics from a little assembly and the glass being put in.
This was one of my favorite shots of the evening just before leaving for the night.
Rest of the glass going in.
New pillar trim and new visors :shock:
If you follow me on IG I'm sure most of these pics are old news, but it's nice to get back on here and have a little more solid documentation and some explanation behind some of the process. I'll have updates when the car is coming back from the paint shop, and then the re-assembly process!
#737 ·
AZCRXSI said:
Impressive!
:)b
Thank you!
audmcrx said:
The white looks super mint, will look great with all the trim back on to balance it out
It will be nice to see it all back on the car, I'll hopefully have updates this weekend when I go to check the progress on it.
Tasos_7R said:
It looks amazing!! Is it possible these days to find oem rubber trims for a crx?? I'm searching the last 4 years and i've found just a few... :(
It is possible, however be prepared for ridiculous prices sadly. What you can order from Honda, DO IT!!! You may just have to be patient and search and put feelers out for other parts. eBay pops up with some random deals at times, you may have your luck with overseas sellers. I had a few helpful people on some of the CRX and EF specific groups. Some pieces you may have to strip down and refinish them yourself.
nihkon said:
Looks great dude!
Thanks man! Can't wait to get the rest of the car together so I can see this thing come back to life!
#738 ·
Thanks!! Yes i am in the process of searching and everything i find on Honda dealers i'm buying it. I think i'll have to refurbish some stuff i won't find... Talking about ridiculous prices, i've found a site that sells brand new wiper cowl panel for $800!!! :shock: :cry:
