61 - 67 of 67 Posts
Discussion starter · #61 ·
yes they will whistle... your air intake and the fact that its sucking in much more air is the whistle. if you go through the rpms at like 40% throttle and get to like 3 grand, 4grand youll hear it..almost sounds like a squeel/swooshin
yeah ive just had a few people say it might be leaning out but i didnt think so just wanted to ask for sure ya know. im bout to put this thing on a 1100 mile road trip this weekend and dont want any problems especially if im not gettin plenty of fuel ya know
Discussion starter · #63 ·
nice dude..congrats...well have fun on the road trip...be safe..and going the speed limit versus 20 miles over...the only way it actually saves you more than like 10 minutes..if you you go 40 over and go that the entire route..drive smart and drive safe..bring some tools just in case..keep extra rad fluid, extra oil, and other tid bits with you just in cnase..i just drove from cali to boston
Yeah so I am going to bring this back from the dead...
So the IAT hole on the newer Skunk2 intake manifolds is threaded because newer models they made this manifold for have the IAT in a different location and the threads were in case the hole needed to be plugged. I spoke to Skunk2 on the phone about it. If your model (CRX) has the IAT in the location all of us are talking about, you need to drill it out to fit the IAT sensor. I took mine to the machine shop and they did it for me in about two seconds, but this can be an easy DIY. I spoke to many different people about shaving the IAT sensor, DO NOT DO IT. It may work and all, but Honda made these things the way they are for a certain reason.
importcustomx said:
i would try sanding the unit only if its a little..but if its a significant amount then just drill the manifold..thats the easier way.
i actually am still looking for a gasket...i used home made cut a gasket from autozone...
Mr Gasket on TH motorsports is the one im going to order..its 6.57..everyone else was 15$
i just put in my skunk2 manifold but i cant get the lines hook up right can anybody help me out plz
Reviving this from the dead, has anyone done this recently( as in the last 5 years)? Just a straight swap on to a D16a6? If so does it still need to be drilled out? Should I ditch the charcoal canister, and how should I properly vent to return tube? And should I replace the map sensor or use my stock one? If I should replace it what should I get? And is wiring involved? I'm planning on getting a skunk2 alpha throttlebody as well to go along with the manifold I that changes anything.
61 - 67 of 67 Posts
