Does anyone know where else to get one? my car got broken into and I want to get another one since it was cracked when ripped out. Maybe God is telling me I shouldn't do double dins since this would be my third after getting stolen twice.
Yes, both spaces are full single DIN, separated by the thin divider strip. I'm holding one as I type this. And both openings in both slots are equal size. If you used the Honda EQ, in the bottom slot, instead of the DIN sized auxiliary CD player, you would also need the thick rubber adapter ring.nihkon said:For those "split' din bezels above...I think it's confusing to call then "double din," as it doesn't actually have 2 full din spaces.
The upper space is a full din. The lower space is, as you said, designed for the oem equalizer or cd player...both of which are smaller than a full din space.
What would you call them then...nihkon said:For those "split' din bezels above...I think it's confusing to call then "double din," as it doesn't actually have 2 full din spaces.
Then I would assume that either:Baker said:What I do know, my accessory single DIN storage pocket fits fine in my split "double DIN" under my head unit.
I dunno. Maybe "single din bezel with accessory slot below?" lolBaker said:What would you call them then...
I think he was looking for the first full open one.juttsin2 said:did someone want to buy a dash kit like the one posted above??? If so... I have one. Send me an email
2 separate slots.
homeslice287 said:i am looking for the fully open double din.
